1 - 3 of 3 Posts
Who makes sprockets for BST wheels on a 2010 muscle? Btw it is a chain drive. The bike has a ton of work and money spent on it but all the work has raised the rpm at which the power comes in. I bought a smaller sprocket for the front from Vreelands and frankly after cams and larger valves and porting the lost torque is noticible at the eighth mile track I frequent. I did buy the bike this way. Frankly, I believe some increase in cc may be the only way to get back the lost bottom end.
"Vrod King"
You need to measure the bolt pattern and center hole first. I've had Rebel Gears make custom ones before for me. The latest ones I've been using are late model HD that are offset from PBI Sprockets.
After I posted the question, I did some thinking and remembered that Brock Davidson sells the BST's so I would think that he may have some info and recommendations. Mike thanks so much for info you gave me and if Brock does not have an answer I will followup with your advice,
1 - 3 of 3 Posts
