1 - 2 of 2 Posts
i just bought a 2006 vrsca. Taking a look around I noticed the rear shock spring preload was set on 1 on the left shock and 2 on the right shock? Common sense tells me they should be set the same. Also is there a chart for recommended settings for the rider weight(s).
Retired, Not SLOW!
There's no chart that I'm aware of, B-KTM, but if you bottom out jack 'em up a notch. And, yep, your common sense is right on target.
1 - 2 of 2 Posts
