I bought my R in November of 07 because I was in need of a sport tourer and the Honda CBR 929 wasn't a good replacement for the BMW R1100RS, my previous ride. I settled on the R because I got such a great deal and the dealer was close by and known to me, bought a Buell from them in them in 96, and the local BMW dealer closed and moved about an hour and a half away.
My initial impression of the R was not good because it's weight really put me off. Going into turns I thought I had to really clamp on the brakes ahead of time because the momentum the bike carried. At the beginning I was reluctant to get much above 4 k revs because of my experience with the Buell and its 1200cc motor and thinking that all Motor Company motors are low end torque and no revs. This season I finally kicked it up and started thrashing the R like I used to thrash the Beemer. Now I follow our group's official squirrel run leader in second gear ranging from forty to eighty without touching the brakes. The throttle controls acceleration as well deceleration like a rheostat. The R's low center of gravity makes riding tight switchbacks a scream. I love it.
It's obvious that the R is not a success. Mine was built in 0105 ! Hell the Motor company probably has misgivings over the whole VROD line. Whatever, I believe that they should pursue VROD development, but make the bikes more capable. Anything other than the R is too low and scrapes around too easily. On the other hand the motor is fantastic and once it broken in like mine it has low level hum at speed that tells you that its in its zone. The R to ST project is a step in the right direction. Bring back the rake the front three inches, but then make the rear swing arm three inches longer and engineer a mono shock in back there. Maybe place the swing arm pivot a little lower to raise the rear equal to the front with its reduce rake. Finally get a on a weight reduction program. There is an easy 100 lbs. that can be eliminated from this beast. The mono shock being a start in that direction. Those front forks look way over built.
Then the Motor Company could expand the range a little and market sport tourers like the R1100RT which is probably the bike I would like to have if the dealer were close by. The marketing boys should have no trouble differentiating between air cooled Road Kings and water cooled VROD Bahn Burners.
