'04 1300
Danii's '60k service' thread brought this to mind. I know all of this info is in bits and pieces in various posts, but it'd be great to have a single list of the things that it makes a lot of sense to replace/upgrade if you're splitting the cases.
So far, this is what I've come up with:
  • Shift Shaft
  • Shift Drum
  • Oil Pump?
  • Motor mount on pre-05 bikes (not really a 'split the case' thing, but if you're pulling the motor anyway. . )
  • Clutch (upgrade to '08 slipper)
Anything else?
Friend of Max.
The shiftfork for 4th and 5th should be upgraded on 2002-2003's as well.
"A" is the only way
change to updated parts: coolant bottle,fuel lines
bigger gas tank would be good at this time
add a oil pressure gauge I think is a must upgrade or change the oil pressure switch to come on at a higher pressure
Pin the main bearings
