A likely culprit besides the battery terminals is a loose ground for the IM.Had anyone had problems with speedometer light blinking on and off at night? Is this possible fuse issue or does a light bulb need to be replaced?
connector on back of speedo unit may be loose. Especially if you have added risers or anything like that. stock wires are to length, not much slop.Had anyone had problems with speedometer light blinking on and off at night? Is this possible fuse issue or does a light bulb need to be replaced?
