Can anyone post some photo about F spark plug and battery, as I'm a noob and know nothing about this bike
Retired, Not SLOW!
Sure ...
... here ya go - a spark plug and a battery. These are from an R but I think you'll find the F ones look very similar (F battery's a bit larger, I think).
thanks, I think I figure out the type of items I need. This might be a dumb question. How do I locate the plug? I'm totally new to bike, so I'm learning basics.
Pat (Patrick!)
Nice!:angeldev:
The Spark plugs are on the top of the heads, under your Airbox cover. The battery, if HD hasn't moved it, is also under the Air box, behind the steering head.
Then you have to remove the ignition coils that sit on top of the heads and the plugs are deep down that hole. The front ignition coil and plug is under the battery. The battery is where Honey B said.
Bicep
Make sure you pick up a spark plug socket to get them out or you might break it off inside and then be in a whole lot of hurt $$$. Since your a noob thought would be good to say. We all had to learn somtime, glad to hear your getting your hands dirty and learning your bike.
