If you are like me you like to look at this stuff. This is an engine I just bought, yes I knew it was broke but did not know exactly what but took the chance. It is a 2008 VRSCDX 1250 engine with approximately 5000 miles on it. I am totally pleased with what I found. The only damage I can find is the rods, rod bearings, and crank. All other bearings and bushings are in pristine condition.
BTW: An entire engine an be tore down to nothing is 28 minutes including a potty break.
Inside the oil pan.
Heat marks on the rods
Heat marks on the crank. Notice how great the main journals look.
Rod bearings worn thin as razor blades. Notice the one on right looks to have 2 layers. That is actually the 2 bearing shells spun on top of each other.
One rod bearing seized in one of the rods
The rod from the layered bearings.
And finally the crank.
Inside the oil pan.
