1 - 18 of 18 Posts
So I take my bike into the dealership to get new tires mounted..and I figure they could probably knock out some warranty work (clutch and brake covers, fuel gauge, the usual suspects). After holding the bike for over a week (needed to order parts) I got the call tonight that it was ready to pickup. I apparently owe almost $400! :deal: Did I mention it was for tire mounting and warranty work? So I asked for a detailed description of the bill, amongst some of the bogus things listed was $5 for missing heat shield hardware. (one screw...yep, that little screw is apparently $5!!!) Then there is other nonsense like shop material, deductible, taxes...somehow that adds up to $400 (with the expected cost of mounting tires, which I wouldn't think was much more than $100)...:soapbox:
Guess this'll be the last time I take the bike to these guys. Time to order that Penn Foster Motorcycle maintenance course...
Just thought I'd share...
Plus or including tires? To do both ends takes about 2 hours, if you have done it before.
Killer Service Inc.
Get the manual and do it your self.
Check out some videos...click on link in my Sig.
If you don't like going to the dealership get the manual & tools and take matters into your own hands. What they do is charge you a "flat rate" cost which means if it takes them 10 min. or an hour its the same "flat" rate you see on the bill, thats how some good mechanics can rack up build hours (and make a living) if they do good, timely work. Politely ask them to explain the details of the bill when you go in and if that seems "nuts" there are the fore mentioned alternatives. I think there is way to much dealership bashing on this site. I personally will never take my bike to a dealership the same way i would never take my car to one. just saying.
Ditto^ :them:
Sounds like a lot, what do I know.
What was the initial quote for the work when you dropped it off?
How much more was it when you picked it up and what was their reasoning? Just curious.
I had a dealership experience where the work was about triple what the initial quote was upon pickup. I got no where with the garage manager. I later called and came in to speak with the owner who refunded all of my money down to the original quote. That manager was terminated a few weeks later.
It must depend on the dealership. I had them swap my front tire from my old rim to my new one, mount a new tire on another new rim, install the hubs and mount them all and it was only $150.
Blowin' Smoke
On the other hand, there are good dealers with good service departments out there. A few weeks ago I went with a friend who had installed slip-ons on his DX. We were headed to a shop 85 miles up the road to install his shiny new SEPST and run it across the dyno. Less than an hour after arrival we were notified the work was complete. Come to find out, the tech took it upon himself to do an initial dyno run to determine a starting point, found out the mapping was fine, and went no further. Cost my friend $38 if I remember correctly. And the tech said "here's your SEPST, I didn't marry it up. You can keep it in case you do more mods, or resell it".
Most shops would have installed the device, then done the dyno tune without question. I figure this tech, and the dealership, saved my buddy almost a thousand dollars.
LOS ANGELES
boredom kills
......the tech took it upon himself to do an initial dyno run to determine a starting point, found out the mapping was fine, and went no further. Cost my friend $38 if I remember correctly. And the tech said "here's your SEPST, I didn't marry it up. You can keep it in case you do more mods, or resell it". ........
I need to find a shop like that on Long Island
1 - 18 of 18 Posts
