Thank you to all of you who take he time to help the rest of us green v-rod owners! For the last 5 days I have been reading as many areas in the V-ROD forums and have found so many helpfull hints and ideas.
I am new to the problems of the V-Rod and the wows of the service Dept.
After reading the experiences you have all had I feel way more at ease with dealing with my broken V-rod.
I introduced myself in a thread (It died and won't restart). I am looking into lengthening the springs in the spark plug boot and getting a new battery!
Does anyone recomend a battery? Is the H-D the best or is there an aftermarket that is better? I am hoping that the battery is the problem. Reading other posts I see that I am not the only one with the same stalling problem. This seems to me that H-D may have a liability issue concerning stalling due to low voltage. Is there a way to keep this from killing someone?I was lucky enough to have my wife following behind me in the truck and was not run over by somone in a hurry!
Oh. one more ?. TSSM relocation? Does anyone know were to put it and how crutial is the orrientation?
:confused:
Thank you TIM
Fireman/investigator
From what I have seen, the HD battery is the only one made to fit, so far. I would think a better charging system would help with the voltage drop/stalling problem. Also, the orientation of the TSSM is crucial. It measures the angle the bike is at, and will kill the fuel pump at a more than 45deg lean (falling over). SOme haev put it under the airbox cover. Sorry, that is all the input I have on this, but I am sure the more knowledgeable ones will chime in soon....
Greg
My battery is 2 1/2 years old and I have 17,000 miles on the bike. It has never stalled or failed to start. My bike has no security system could this be the problem?
Greg
Thank you for you're reply! Every little bit helps. IT is just so frustrating after puting out so much $$$$$ to have so manny problems!
