1 - 2 of 14 Posts
No adjustment. Sounds like a clutch issue.The clutch is not releasing properly. A number of issues could be the problem. Dirty fluid ,Clutch Master cylinder, slave cylinder. If the fluid is clean. Then you may have a clutch problem. How does the clutch lever feel? If fluid is dirty, the clutch master cylinder could be plugged. Check these first before blaming clutch. You may need to flush system.
Certain oils are not made for clutch use….be sure to use good oil. 😁
1 - 2 of 14 Posts
