Started this on another thread and decided to start a dedicated thread to so as not to change the subject of the other thread and to get as many people involved as possible.
Here's the deal guys, I have limited mechanical ability and do not want to spend money on machining so I am looking at finding a way to drastically reduce my RPM (15% to 25%) for touring at highway speeds. My idea scenario would be to bolt a smaller rear pulley in place of the original or a larger front pulley and install a new shorter or longer belt. The problem is front pulley shaft/off-set compatability and/or rear pulley bolt pattern/off-wet compatability as well as belt widths. I thing finding the right legth belt would be pretty easy.
Here's the info I gathered so far from checking ebay and parts catalogs:
VRSC specs:
Front pulley: 28 or 30 tooth
Rear Pulley: 72 tooth
Belt: 1-3/8" wide, 149, 150, or 151 tooth
Buell specs:
Front pulley: 27 tooth (Euro 30 tooth)
Rear Pulley: 65 to 70 tooth
Belt: 1-1/2" wide, ? tooth
Other Harley model specs:
Front pulley: 29 to 34 tooth
Rear Pulley: 61 to 70 tooth
Belt: 1", 1-1/8" or 1-1/2" wide, 125 to 149 tooth
It looks like there are enough pieces out there to to get the gearing I want the question is whether or not the pieces will "bolt on".
Please let me know what your experience has been. Anybody mounted a Buell or other HD front pulley or rear pulley to your R?
VRSC specs:
Buell specs:
