After installing the two nuts that fell of the rear cylinder manifols studs I did the smoke test for leaks and all was good till I saw a drop of condensation hit the garage floor where the slipons clamp to the header pipe.
I removed the heat shields and felt around the clamps. Turns out that I have several small leak where the cuts are made in the slipon inlet to allow the clamp to squash it to the head pipe.
The clamps were torqued to 45ft/lbs and are not getting the job done.
What are my options?
