Hey all,
My '08 VRSCDX has developed a strange problem.
If I leave the bike for more than a few hours then despite showing as in neutral as soon as I try to start it I get a Sidestand down message on the digi display.
Raising the stand will allow the bike to start but I cannot then put the stand back down without it cutting out (neutral light still showing). UNLESS i pop it into first, roll forward slightly and then back into neutral. Only then can I drop the sidestand again and do my pre-ride prep with loggage etc.
This only occurs once the bike has stood for a few hours. I've changed the sidestand sensor already and it hasn't solved it.
I'm lost any ideas anyone?
Fah q 2
look to see if your throwing any codes
It was throwing up a sidestand error code but when I replaced the sensor that stopped appearing.
Driving me batty.
:banghead:
I didn't know any V-Rods had a stand sensor. I wish mine did.
These aren't used on US domestic models but are required in Europe.
I don’t think I'd want one (it’s just another thing to go bad) but you could add one for about $50 if you have a 2008 or newer VRSC.
The parts you'd need are:
  1. the JSS (jiffy stand sensor), 50277-08A
  2. a screw with 6mm x 1mm pitch threads to attach it to the frame
  3. 3 Molex pin terminals (72169-07)
The connectors for this sensor are located under the left side radiator cover on 2008 and newer models. US models should have a dummy connector in place of the sensor wire connector that the HDI models have. The JSS sensor wires should be installed in the connector as follows:
  • red wire in position 1
  • white wire in position 2
  • black wire in position 3
is it possible you are showing a false neutral? There have been times that my bike showed neutral, (usually when parked on a slight incline), but it wouldn't roll forward or backwards as the tranny was still part way in gear. Once I pulled in clutch and rolled bike a few inches, and put it in neutral again all was well.
This seems to coincide with the oil being near the end of its life cycle.
Thank you very much for that information. My next mod!
I don't know why, but I can't seem to remember to put that damn stand up when I get on the bike. Sooner or later, it's going to take me down.
Problem Solved.
Well it appears that it was the battery which was causing it by fluctuating it's voltage.
I noticed it initially as it wasn't starting up as robustly as previously and I'd had to charge it twice in as many weeks. A quick check showed that although after charge it would look fine as soon as you fire it up a few times the charge and voltage droppped dramatically.
I replaced it and voila, everything is fine again, no false reports or sidestand being down etc.
Thanks everyone. :)
