1 - 10 of 10 Posts
Need some help! What tools will I need and how do I unbolt my shocks so that I can mount the Rizoma turn signal relocators. I found another post but it didn't tell me how to unbolt the shocks and put them back together.
8mm allen wrench for shock bolts. The uppers have an integrated nut under the fender that I did not have to put a wrench on.
You only have to remove the upper bolts to install the Rizoma TS relocators.
wfbont007, while it is possible to remove a single shock on the ground it is not advisable to do it this way. A lift would be the safer route to take.
Max
Fireman/investigator
wfbont007, The back end of the bike will sag with just one shock. That means that when you try to remount the shock, you will have to lift the back of the bike. Not easy by yourself, and never a stable thing to do ;)
Lift is the best way.
Greg
When I did mine I was able to get the bolt through the shock and the frame w/o a lift. What I could not do was get the nut started. The pressure on the bolt caused it to angle down. Since the nut is also a spacer, I could not get it treaded. I got a lift, and it was a piece of cake.
Good idea John. I will keep that in mind. I want to replace these stockers with something nice.
Greg
1 - 10 of 10 Posts
