1 - 7 of 7 Posts
I see there are a few threads about "Shifters Sticking" down and when down shifting. I just had the 5K service done and now when shifting UP thru the gears the shifter stays in the up position after each shift for an extended period of time (3 to 5 sec or so...). I'm not cranking the throttle on, just getting up to speed with traffic. Happens thru all gears.
Any ideas???
Thanks
Dave
Oh yea... '06 VRSC"D" 5,250mi
Discussion Starter #2
HUMMMM??? 30 looks and no replies? Is my problem that unique?:stilpoke:
You need to remove the shift lever itself and lube the shaft. The 5k is an oil change and a wallet drain. :)
Discussion Starter #6
Thanks for the info. The bike is at the dealer now to get the front rotors replaced (Pulsing). I mentioned the problem and we'll see what they come up with???
Discussion Starter #7
I guess a little lube goes a long way... Cleaned and lubed all external moving parts, works great again...
1 - 7 of 7 Posts
