Hi folks so i really need to bring my shift foot peg up some .big feet and all. Is it adjustable ?thanks
Small amount of adjustment on the rear hiem joint. I added an offset piece to get where I needed.
hey man, where did you get that offset piece? and also where did you get the black clevis piece that connects the shifter to the bike?
Shift peg mods are home made. That black jogged piece is stock in the 2012 and up for that reduced reach effect. The reduced reach but not moving the shift peg with it , is what spawned the shift peg mod. Brake peddle also has an extender pad on the peddle.
Reduced reach footpeg kits 50270-02A can be used two ways. To get pegs inch closer or other way around inch wider. Not up or down (without modification). I use for the widening with B-model. These are for front controls only. Does not fit with mid-control R models.
