Well I cut the inner baffles out of my exhaust now I understand it is hard to explain how to do. On the inner side that comes out of the headers I took a carbyte bit and grind the metal down thin so you can fold it inward because there is 2 tac welds that holds the baffle on this side that you can't get to.
On the end of the pipe I took a plasma and cut a circle as close to the factory exhaust hole then took the carbyte bit and started making the hole bigger a little at a time till it was big enough to slide the baffle out. The hard part is making the hole on the end of the pipe round because the end of the pipe is not really round. Will take some pics later today. :spank: :spank:
