· Registered
tried to bleed my brakes today for the first time. All 3 bleeder screws are seized and ended up rounding each of them. Are the replacement screws universal? Also any tips on removing them?
· -MIG
Delilah, my '16 Muscle & Fiona, my '14 Triumph Rocket III Touring
Protect the pads but spray the bleeder screws with a WD-40 or a good penetrating oil. Let sit for awhile and then use vice grips as mentioned.
-MIG
· Registered
Best wrench to use is brake line or fuel line wrench. I didn’t have ether so used 6 point I would recommend 12 point. Now just grab some off line replace them. They should be fine thread , if you go by automotive store look for thread reader to get exact ones look in tap and die set also if you have one there should be thread count there or match tap set to thread
2005 VRSC? 44048-83*
BLEEDER FITTING two for $5.49
Look up any year hd
