21 - 39 of 39 Posts
Some questions for SteveandMollie.
Does the bike run at all?
Does it have an audible alarm associated with it?
if the bike will start, Move the FOB a good distance away from the bike, like 15 feet or greater. Try to start it.
What happened? did it start or no? It shouldn't if the security system is working.
When you shut the bike off the security system will automatically activate. The turn signals should blink a couple of times. If you have the audible alarm it should beep at you.
RUN to your H-D dealer and purchase a Owners manual for your year and model. It will explain how the security system works and how to set PIN numbers etc. The process is rather involved so someone bent on stealing your bike from the Wal-Mart parking lot can not remove and replace the security parts easily
Thanks RustyG. I actually bought the bike from a guy in Orlando and friends of mine were at Biketoberfest so they brought it home for me to Ontario , Canada. The bike started and ran no problem then but it's been sitting for a while because of our lovely weather up here and when I went to start it it the signals flash constantly and nothng happens when I press the 'Start' button. It didn't make a difference if the FOB was beside the bike in my pocket. or on the air box or 50' away in the house. There is no audible alarm on it that I know of. The signals flash about 15 tmes before they stop. Is there a chance the battery in the FOB is dead or dying? There is only 250 miles on the bike.
If the bike has been sitting for more than a couple of weeks I would suspect a dying/dead battery. Put a charger on it over night.
The signal flashing 15 times probably is the security system telling you someone is tampering with the bike. I have never experienced a FOB battery failure but may be worth changing.
Since you rode it before storing it that means the security system was working at one time and the FOB was operational.
Do you hear a clicking sound when you try to start it? This would indicate a possible weak battery or loose connections to the battery/solenoid.
What year and model is the bike?
Ok it makes i get it now btw mine is an 02 so it has to be manually armed and disarmed. I do not have the manually so i have a stupid question. If i arm it will the bike start?
Hi again
The battery voltage is at 11.49 volts and the bike has been in a heated garage since we got it. I have a battery tender ordered that I hope to have by this Wednesday so I'm going to get that put on and I'll put a new battery in the FOB. There was no clicking sounds like the starter trying to engage when we tried to start it. I'll try the new battery in the FOB and give the battery tender a couple of days to re-charge the batttey if needed and go from there. This bike's a little more high tech than my '84 FLH Shovelhead. I'll let you know how I make out. Thanks again for all your help and advice.
Oh yeah, this is a 2007 VSRCAW, Pacific blue pearl with 281 miles on it. I'm in the process of putting Kuryakyn Gran Throw-over bags using stainless steel tubing for the supports and Custom Dynamics rear LED signals on it but I want to get the security system sorted out first. Thanks again. Steve
11.49V should be enough to at least click the start solenoid when the start button is pushed.
Question. With the FOB close at hand shake the bike vigorously or at least make like you are going to steal it. If the lights flash more than several times then the Security system is armed and not recognizing the FOB. What were the results of this test?
Are you sure you have the right FOB? Did you start the bike after you left the sellers location? Could be he gave you the wrong FOB but the correct one was nearby when you rode off.
The bike will not start with the security system armed. Double click the FOB button to disengage the security system.
Hi again
When we got the bike home back in October we did take it for a short ride(we had no licence, insurance or any paperwork done to get the title changed but it was a nice Sunday afternoon ) so the FOB was working then and must be the correct one. I tried shaking the bike with the FOB nearby and the lights flashed only once unless I shook it more and then they'd flash once more. I took the FOB back into the house(@30ft behind 2 closed doors) and shook the bike and had the same results as when the FOB was with me. I put the battery on the charger before I left for work this morning and it made no difference either. My wife is going to be near our closest HD Dealer tomorrow so she's going to get a new battery for the FOB and we'll see what happens then. Thanks again for all your help and advice.
Hi again
Does sound like your FOB isn't working. Go to Radio Shack or wherever you get batteries for watches etc for the battery not your H-D dealer. You will save a bunch of money. Battery type is CR 2032. It's about the size of a nickel (USD).
I have a audible alarm on my bike. If the FOB is not present and I get on the bike and straighten it up I will get one beep. If I persist it will wail like a stuck pig. The security system w/o a audible alarm works similarly but uses the turn signals. First disturbance a single light flicker. Continued disturbance then many flashes. So it sounds like your security system is working.
PS. Once you get it working get an audible alarm. It's simple plug and play. Take off the passenger pillion, locate the appropriate connector and plug it in. That is it. This thing is LOUD and will scare off any casual bike interlopers.
Fear The Reaper
I've had this happen to me with my FOB. I too have an 07 AW and the batteries in the FOB's can be great one day and crap on you the next. Once I replaced the battery, all was good in the world.
Hi again . We got a new battery for the FOB and that cured our security system problem. That was a lot of worrying and thinking for an $7 battery. We got a Sony CR2032 Lithium 3V if anyone's looking for a part number for them. Thanks again everyone for all the help and advice, it was really appreciated.
Glad that's all it was.
Security System
I just installed on my 03 VRSCA a Harley Security System Siren II along with Rechargeable Remote Pager II with no problems with either one, just followed the directions and took my time. The lights all flash like the book say. However, I don't get a chirp when I set the alarm. Anyone else have this problem? Did I miss something?
FOB Battery Strength
FYI...
I wasn't able to start my 08 VROD. In my opinion, 2.84v and 2.76v should still be enough voltage. However the HD alarm system disagreed. New CR2032 3v batteries are actually 3.25v fresh out of the package. Once I swapped batteries I was able to disarm the alarm.
'07 and later?
In case you lost your security system card (or never got one) from the owners manual here's a copy you can print out and carry with you.
This is great for the pre-'07 bikes with the button on the fob... I have an '07 without the button to push. Does anyone have the card for that one, for setting / changing the code?
Thanks!
Retired, Not SLOW!
Security System Wallet Card
Thanks!
Yep - hang on. I'll go get it and scan it in.
Here ya go:
I also have the entire Security System section out of the manual in a Zip file. PM an e-mail addy if you want it; it's 10.7MB.
Here ya go:
Thank you very much!!! Now to see if I can follow these instructions and change the darn code! :deal:
Thank you MJW930
13 Years latter and this was just what I was looking for my Early Security System!
The 2006 Street Rod I bought used came with a TSSF factory alarm. I bought a used FOB and married it to the Alarm, and reset the PIN to one I can remember.
Now I feel better I can use my PIN to disarm the security system if the FOB craps out or I loose it.
P.S. No I didn't steal the bike and I have the registration to prove it! LOL
Thank you MJW930
Got my pin burned into memory. Dealer set it and wrote it on the card with owners manual. Have never needed it but I'm ready should the day come.
21 - 39 of 39 Posts
