1 - 12 of 12 Posts
Greg/Moderator
I can't get the fob to activate the security alarm. I check the batteries in the fob and siren, they both are good, I check the connections for corrosion and no problem there. RJ my fine friend.... sent me the key fob assignment procedure and that did fix the problem either. Turn signal or security light in the cluster doesn't flash or light up. Any help would be great !!!!!
Thanks Greg
KC Rally Vet
Hey G, give Danno a call... He can give you the repeat lesson he gave you at the rally.:stilpoke:
1130cc Ninja
Greg, does the alarm have a maximum number of remotes that can be programmed... I know some car alarms will only let you do 3 or 4 then you have to delete all of them out completely and reassign them all.
1130cc Ninja
what was the operator error? :)
Friend of Max.
The alarm can only recognize 2 fobs. If you program it to a new fob, it bumps an old one out of the memory.
Greg, what was the issue?
1130cc Ninja
kickass :notworth:
glad to know I was on the right path with that one!:deal:
Is there a way to program a second fob w/o having to take it into the dealer? is there a thread and procedure on that?
1130cc Ninja
there is, but I think RJ will have to PM you on that one.. i havent seen a "thread" about it.
1 - 12 of 12 Posts
