There are several "mods" posted here on the forum... the one that completely removes the baffles is the one that Chopper Steve does, and the one that I have.
well that's the one I was looking into doing... thanks.brentley said:There are several "mods" posted here on the forum... the one that completely removes the baffles is the one that Chopper Steve does, and the one that I have.
mjw930 said:Ok, I've seen replies all over the map with a lot of confusion on what an SE pipe is. Here is a rundown
SE Slip Fits = Looks like the stock pipe on an A model with a different baffle system. Fits A/B/SE/X models ONLY. This requires a remap
SE Hollow Points = For R/D/DX models ONLY. they look like the pipes on these models with a brushed finish. No remap required
SE 16 GA = Looks like dual straight pipes. For A/B/SE/X models ONLY. Requires remap.
All of these have a "V-Mod" capability where part of the interal baffle is removed. It's different for each pipe but historically the appropriate SE flash works OK with this mod. If you have an R/D/DX then you'll need a Race Tuner or other device if you modify it since there isn't any SE flash for this pipe.
really? I wonder why that is.. I thought the SE pipes just had a little internal baffles than stock ... And in the end, aren't you just removing them?brentley said:Yes, but be aware that the v-modded SE slip fits are no where near as loud as the v-modded stock pipes... (I have both)
Mark the slip fits DO fit the AW... (personal experience)mjw930 said:Ok, I've seen replies all over the map with a lot of confusion on what an SE pipe is. Here is a rundown
:them: I have mine vmodded by Steve and with stage 1 download. It runs great.brentley said:Nope... the stage1 download covers the v-mod.
For identification purposes also note that the SE performance slip fit mufflers have a "Screamin' Eagle" script on the top muffler. If you are looking for a set, beware of ebay auctions calling the stock CVO exhaust, a SE slip fit muffler.mjw930 said:Ok, I've seen replies all over the map with a lot of confusion on what an SE pipe is. Here is a rundown
Hi, did you buy them? do they (an '02 ) fit your AW07?dstlvb said:I picked up my new 07 AW yesterday and went for a short ride today. While out a guy on a road king was telling me about his 02 vrod and that he had a set of SE he would sell me for 100$. He had taken them off to put on some jokers he said. Said they were in great condition with no marks. Now i want a little louder pipes with a more rumble. Would these pipes or slip ons accomplish that? Also on HD website they say they fit only R and D models, would they work on my AW?
I stuck a set on an AW07 and they fit like the stock ones fit... no issues.taketi said:Hi, did you buy them? do they (an '02 ) fit your AW07?
Thanks.
The "stage one download" was/is and ECM update for the Screamin Eagle Pipes and aircleaner. Dealers provided this $$$ add-on when they sold/installed the Screamin Eagle pipes (for the V-Rod) as an option.My-V-Extension said:Stock A pipes V-moded (baffels removed) work just fine with a 33321-05 SE Cartridge down load. You will need to have a SE/Amsoil/K/N Air filter, go topless (remove completely the black air box-top with the snorkel) and relocate the temp sensor.
Bike runs great, though I do need to let it warm up for 5 minutes before riding or it will stumble around 3000-4000. After that, all is excellant! Not sure if it is because of the new found noise, but the bike seems to be much more powerful.
From my understanding there is no such thing as a Stage 1 down load for the V-Rod, unless that is a generic carry over term from the air heads.
Not sure any of this applies to the new 07 AW, but hey thought I would input just to add to the confusion.......
