1 - 20 of 36 Posts
· Shady
I picked up my new 07 AW yesterday and went for a short ride today. While out a guy on a road king was telling me about his 02 vrod and that he had a set of SE he would sell me for 100$. He had taken them off to put on some jokers he said. Said they were in great condition with no marks. Now i want a little louder pipes with a more rumble. Would these pipes or slip ons accomplish that? Also on HD website they say they fit only R and D models, would they work on my AW?
· Shady
They are SE slip ons that have been drilled. Will i have to get a Race tuner or a download to use these?
· John
They will fit the AW...
The "stage 1" download for the SE pipes will work (or a Race Tuner or Gils box for adding a little richness to the system).
Add a good air filter (like the amsoil).
I run with the SE slip-ons on my 06SE2 and run Jokers on my 02A. One bike is for Sunday cruises (won't upset the neighbors) the other sounds like NASCAR down the straight-away.
The SE slip-ons were 600$ new... 300/400 used in good shape so 100.00 is a "give-away" price. The sound is at least twice that of the stock system and under WOT sound good.
· Shady
My Next question is how much does a stage 1 download cost? If i add the pipes and wait on the filter can i run the bike till i get the download or will it damage something.
· John
You can ride it a +/- a hundred miles without the download. I wouldn't ride it much more than that as it will be leaner than stock (and stock is already lean).
Besides, it wont run "right" till you add all the ingredients.
· Registered
I would suggest researching further.I have researched quite a bit (online, 3Harley dealerships and 2 aftermarket dealers) I also have a new 07 AW and was told that the SE slip ons will only work on the 07 Streetrod & 07 Nightrod.
· # 12/50 Ignite LE
I believe you are talking about the SE Hollow Point slip on mufflers which are no longer made either.
· Skitzo? Perhaps...
is this true?? I have the slip-on's with a stage 1 download and have recently been considering doing a VMOD exaust.... But I was concerned about needing a fuel managent system. So are you saying that I won't need one if I already have the stage 1 download??
If that's true I'll be a little more on the right side of the fence.
· John
If you v-mod the exhaust you definitely need a fuel management device.
landglider said:
I think you're wrong Brentley.(unless you're referring to the DIY "self made" v-mod modification and not the "V-Mod" pipes modified by Steve at V-Mod).
Damnit it you 2... you're dangling a pork chop in front of a STARVING MAN!! :rofl:
What would be the difference in the 2 mods?? I thought they were the same...
I have an 05 A ... ... now make up your minds :spank:
:cheers:
· Registered
landglider said:
I think you're wrong Brentley (unless you're referring to the DIY "self made" v-mod modification and not the "V-Mod" pipes modified by Steve at V-Mod).
Then maybe...
The SE download that you would flash when purchasing SE pipes richens enough to cover v-modded pipes (from chopper steve) also. I happen to be running that exact setup, and if anything, I'm too rich.
brentley said:
To be more precise, I have:
Topless
K&N Filter
v-mod stock looking pipes
SE flash
That's the setup I have now (sans the modded pipes)
is there a difference in what Chopper Steve does with his V-mod and the do-it-yourself version that we have instructions for on the forums? I can't imagine there would be, but I could be wrong .
1 - 20 of 36 Posts
