Hello guys
I want to change my rear tire on my VRSCB 2004.
I tried removing my rear mufflers and I had a problem with this screw I put some WD40 in it was seized up. what happened is when trying to remove it i messed up the fingerprint my key turns and no longer hooks the screw what should i do? Thanks. Excuse my pour english, Î am french.
607462
VRSC est -03
Welcome to 1130cc.
In many ways those allen head bolts sucks. Find a torx bit/key slightly oversized and drift it into the allen head. Get a new bolt and use a torque wrench during installation. And antiseize.
thank you, your trick worked; Great. I don't know if these screws are inch or metric; ; because if I have to change it.
Thanks. I just remove the mufflers. I can't get the nut off the axle. He is stuck. the wd40 has no effect.
VRSC est -03
Muffler bolt/s M8. Torque 23Nm.
Rear wheel axle nut torque 129-142Nm.
