I got a set too - same valves, ports were CNC machined by Wegner automotive a pretty damn nice job ! They need a little transition porting from the different CNC angles where they come together and general cleanup with a dremel tool but overall very good. 1250 heads are more restrictive but still work fine in most cases on stock engines. CNC heads have been used in engines to 165 Hp+ with no problem. If you look at S/E CNC and late model 1250 as cast heads side by side it's pretty evident which is more open. At some point valve diameter is the restriction, I'm putting AV&V valves in mine and for what I do with the bike they will be close to a full port and +1MM seat job. Comb. chamber should be the same, but watch out for valve seats that protrude from the dome surface, I got 3 CNC heads and one is terrible in this regard, I rejected it at first glance.
