Yes, standard procedure when installing new clutch friction plates is a 10-minute soak in appropriate 20W50, wet clutch compatible engine oil before installation.Good morning to you all, I’m about to install a new clutch for my 2003 v rod, screamin’ eagle slipper clutch, my question is, before install the clutch do I need to put the clutch disc on a bath of oil before installing.
What 5 bolts on the slipper clutch?Thank you Stever975, do you know if the torque of the 5 bolts of the slipper clutch, is the same of the original clutch?
I would soak the whole assembly. It'll get soaked eventually anyway.Sorry I mean the 4 clutch springs and 4 flange bolts, but is better to disassemble the clutch and put only the disc in a bath of oil.
Thank you ��
