Okay had a thread on here about this before but its archived. Bike runs rough at idle and bogs down on take off or trys to stall at light it dose not do it all the time. Checked fuel pressure changed plugs replace a leaking breather hose on rear that was spewing oil on rear coil thought that was it but it wasent started up again and coil is clean and dry. No codes nothing grounds all tight bike is charging okay. removed the PC III and still have problem so it was not the problem the IAC funtions okay. I need help this is driving me crazy Had to park the sucker for awhile due to a injury but want to ride now and not have to hold gas while at a light. Bike runs good while giving it to her. If a coil was bad should get a code. Heck the way it sputters should get a damn code. This problem comes and goes but has gotten worse. Anyone else have a problem close to this?
