I have decided I want to run topless. I am a bit cunfused about running bike that way. Relocating iat I under stand. I am running a 2003 SE aircleaner and SE slip exhaust with 28 tooth gearing. The dealer set it all up when bought. To run topless do I need to have another flash done? I am not real familiar with all the flashes. The dealer charges $150.00 to flash bike the first time he did it for air cleaner and pipe. Should I buy PC III and get it over with. I assume if I had PC III I would no longer need dealer for flashes?? Thanks in advance.....Tony :angeldev:
Tony,
Check back with the dealer and get the part number for the f"lash" they installed, they may have already flashed it with the appropriate "flash" for running topless,28,K&N and exhaust. If not, pickup a PCIIIr off eBay and have fun...
Pan American Son of VROD :-)
I ran topless. It was a little cold but I think I understand the rush that everyone seems to get. It sure attracts attention!! ;-)
V-Rod Lady said:
Dumb question....what is "running topless"? :stooge:
Call me just a girl but being a novas rider I do not understand "running topless" :confused:
~Heather~
"running topless"= removing the plastic air box cover. I now run topless with the PCIII and V-mods good for a couple of horses. Do a search on "running topless" and you should come up with some good threads. Some of us have also moded the plastic air box cover by cuting holes in the front.
I seek only water...
~Heather~
Heather -- it means taking the inner camshell off. (The black plastic piece under the airbox cover.) Topless provides greater airflow -- more horsepower, but a leaner fuel mix.
