1 - 3 of 3 Posts
My Vrod runs poorly and has since 500 miles ago when I mistakenly ran a regular tank of gas. While it's warming up it sputters and sounds like it's missing. Once warmed up when I let off of the gas after full speed it will occassionally die. Do I need to clean out the fuel injectors with some addative??
You may have fouled one of the plugs, I'd start there.
durata membro
Regular gasoline did not do this to your engine.
There must be some contaminates in the gas you pumped in the tank.Get a sample of the gas in a clear jug.Suck from the very bottom of the tank.Hold the jug up and you will see any water or other junk separate in the jug.If this is the case,pul the tank,clean it and install a new filter.Then try some concentrated injector cleaner in 2 gallons of fresh gas.
1 - 3 of 3 Posts
