1 - 10 of 10 Posts
So I have a 2002 vrsca and I am having issues where the idle surges, I need to get the bike constant throttle when warm to start it and when it's running the engine does when I let completely off the throttle, looking for some ideas at what to look at to solve these issues
IAC motor.
IAC motor.
IAC motor is brand new
The Hawk
Did you reset the new iac motor after the install? Cycle ignition with run switches run, off and on 3 times , 10 sec on 10 sec off.
Sent from my iPad using Tapatalk
The Hawk
Any codes?
When you turn on the ignition do you hear the fuel pump run for a few seconds? If so, take the gas cap off and look in the tank with a flashlight while the fuel pump is running, if you see a fuel mist or spray you have a cracked fuel flange, known issue in 02 and 03 v rods. Easiest to see with a 1/2 tank of fuel or less.
oK so 2 of the problems have been fixed by replacing the throttle boot but the bike shuts off when squeezing the clutch lever coming to a stop every so often and i went through relearning sequence any ideas
In 02 the IAC sensor was attached to the front cylinder. A recall to correct a stall issue remapped the ECM and relocated the IAC sensor to the airbox.
Hey Lemerande,
Where did you order the boot from and would you recommend them?
Sam
1 - 10 of 10 Posts
