Thanks...go to the local hardware store and pick something similar up for alot less money than at a dealer. here is the 07 part # and description 11519A bushing (2)
great idea. i'll do that when i get mine out of storage next month.You all should use some window caulking , glue or silicone .
When installing those
My preference is Dap dynaflex 230 .
I havent had one pop out in years
Thanks...
:them: I put a lil slicker then snot Rowes assembly lube in them just to help slide the pins in but I never had a problem putting the box on once I got the trick downHmmmmmmm, I guess I do it so often - not a problem. I open the seat, line up the left side, bend over the top, line up the right side, and fasten the dzus. Takes 10 seconds. Practice 20 times - you can do it in the dark. Joe
There is a " knack " to it. 1st time, I wanted to throw the thing across the yard. Now, it's old-hat.Hmmmmmmm, I guess I do it so often - not a problem. I open the seat, line up the left side, bend over the top, line up the right side, and fasten the dzus. Takes 10 seconds. Practice 20 times - you can do it in the dark. Joe
