21 - 40 of 239 Posts
reservation dogs
TWO! I assume the 08 is a coppertop, but what color is the 07?
An '07 D , Pacific Blue Pearl. The '07 will be finished first, with H-D style bags. Toni will be riding the '08 to KC this year so it will be started when we get home, and it is going to get the Corbin Fleetliner bags.
Awesome! Looking forward to more pictures. Joe
OK, Martin and I are going to KC - who else? I would love to see a large display of these, and Bat-rods, too! We need to convince the MOCO to build a better touring mount! Come on down - 1st beer is on me! Joe
Geezer
We need a category for the bike show. Otherwise we're all likely to be classified as 'rat-rods' by the I-Love-Lux contingent. :deal:
I had mentioned that to JSC, as well. If we are going into the rat catagory, I can stop polishing!
Still in the Process of converting
07 vrscd got the road glide fairing with the stockwindshield from the partlist from cyclevision , but I'm having touble with mirrors they seem to hit the windshield, open to all ideals do I need to change handlebars. also any ideals on gauges to put in the fairing.
I had the same problem switched to D bars. You will need an extended brake line as well. I put speakers in my holes.
Darth Veeness
2006 VRSCR, started 10-07, and continues to evolve. On the road late spring, and the mods continue! STREETRODROADROD - too long a handle. Need a shorter one - Any ideas? Joe
How about VRSCRG? or V-Glide?
Since you alreayd have a D, changing to D bars will not help. You might try the black 883R sportster bars. They have slightly more pull back than your stock bars. In either case you can rotate the bar toward you and down and then rotate the controls in the opposite direction and that will give you more turning room. Another option is to change the windshield. I changed form the stock to the short black one in my avatar and that worked even with the stock bars on my R. Since then I have tried the Klockwerks shield and that helped but did not totally solve the problem and now I have the 14" Memphis Shades FLT replacement shield. With the handlebar adjustment I mentioned above and moving the mirrors to the lever hole, I can now make a full turn.
Which speakers did you put in the gauge holes?
DK,
Below the front mount inside of the fairing are two small holes. Thru those, use a 1/4 inch drive socket with a 1/8th socket. The headlight mounts in 3 places, and the lower two mounts are studs that are cut in a hex to allow you to aim the headlight. At least up and down. Sounds complicated, but the alternative is to remove 10 fasteners, and the lower mounting bolts, turn signals, and then pull the outer fairing. The headlights mounting studs will be easy to get to, and you can screw them in or out. Then put it all back together. Easy to do, but time consuming. I have done it easily a dozen times. Pm me if you need help. Joe
2003 Chrome Road Rod
road rod stuff
found the adjusters thanks, Capn. will take a socket and adjust on way home tonight. (BTW mine are 3/16) 34.8 mpg not to bad BMW was 42 to 44 depending on throttle urgency, I have to admit I was seeing how this one runs so next mileage should be a little better. Actually this is no slouch. probably rattled some windows with those rhineharts, man they are loud, may have to tone that down a bit.
TomVrod,
Thank for the info, I'll try adjusting down first to see if I can get any more turning distance. hope aleast to get enough to allow to sit on the kickstand.
Chrome Road Rod update
bought a windshield for the winter from baggers-only on ebay, added chrome levers and reservoir covers, luggage rack and mini-backrest, larger tank, have 13.5 shocks coming so I can use all of the tires before the rhineharts touch. Have guard dawg coming from Rowland, adding illumabezel as I need to replace front headlight cover anyway (tabs broken) updated pic
:plause: WOW!
Retired, Not SLOW!
... now if someone will show me how to adjust the headlights!
FLTR headlight adjustment procedure is sorta weird. Still have my Service Manual so if anybody wants the procedure I can scan it in and e-mail it. Adjuster hexes on '03s are 4.5mm, btw. ... dave
road rod improvements.
headlight adjustment, for those of us who don't have the 4.5 mm socket which is .177 the .187 3/16 seems to work. The conversion kit only allows use of the two lower adjuster holes I thought there was an upper one but its covered by the bracket. Would not mind seeing the procedure just to know though. Put the 13.5 inch progressives on like them much better as far as cornering clearance and ride. The clear advantage integrated tailight makes the rear turn signals more apparent to others also. Putting the illumabezel on in the next day or so will post pics of front and rear when its done.
