1 - 18 of 18 Posts
Hello,
I am looking for the rizoma handlebars with the chrome housing for the speedo. As in the image link.
If there is a similar handlebar with speedo housing that will be good too.
Thank you
VRSC est -03
Looks great! And the B2 version runs hidden wiring, something Rizoma didn`t do.
I did actually shorten the cables. It wasn’t really necessary but I wanted it to look clean. I shortened throttle cables, shortened brake line and clutch line. I extended the hand control wires and finished them with techflex braided sleeving (chromexc) and put the connectors in the battery well. To get the extra space for the wiring I purchased the lithium antigravity small form factory battery.
I purchased the HelPerformance kit for the brake which includes the splitter that goes under the triple tree:
And the clutch line from Helperformance:
For the throttle cables I bought the matching braided ones from venhill:
If you have any other questions I’ll be happy to help :)
Hello,
Thank you
Looks great! Does the set-up also work with the stock brake, clutch and throttle cables as well? What speedometer housing model did you use? cheers Tom
Discussion Starter · #15 ·
Hello,
It does work with the stock brake, clutch and throttle cables. I did change mine as I wanted them to look new. See my post above and I have links to what I ordered.
I used a VRSCF (muscle) speedometer and housing. I sent my Speedo off to DutchLED and he made it look pretty.
Hello,
Thanks - the setup looks great. Regarding the speedo housing - did Scott and the team help you with finding one or did you find one on eBay? I have been looking for alternative housings as I know the VRSCA one will not fit with these bars - not found anyone yet unfortunately. I understand that other housing will work as well (B, D, DX). Do you know if you can re-use your VRSCA speedometer with the VRSCF housing?
Discussion Starter · #17 ·
I just bought one on eBay. Scott did say he could help but I researched it a bit and decided to go with the VRSCF. If you look at the other housings they normally attach to the clamshell and have a bigger opening on the underside of the housing. The VRSCF housing has the smallest opening that fits the Speedo wiring.
You cannot use the VRSCA housing in a VRSCF Speedo.
Great! Thanks for your help. Then I take it that I need to look for a VRSCF housing and speedo and totally remove my VRSCA setup. I need to continue search eBay :)
1 - 18 of 18 Posts
