:them:Max said:Are you running topless? Did you remove all the clips that hold the top of the airbox if you are? If not are all the clips good and tight.
The flat rubber pads?wilsomw said:Also there are rubber grommets olonf the edge of the air box where it meets the frame. How many should there be?
wilsomw said:Yes I took the air box cover, top of the air box and the air cleaner out to check every thing out. Why?
lakedrunk said:I had a noise similar to what your talking bout and it sounded like it was coming from the airbox (I swore it was) but it ended up being my heat sheilds on the exhaust were loose. it seriously sounded as if it was coming from the airbox, I felt stupid when I noticed the little screws loose on the heat sheilds.
I didn't loose the screws, they were just loose. but that was back when I had my "cheatin" style exhaust on, I've switched back to my samsons now and don't have to worry about them little screwsmyvrodrocks said:You have loose screws... :stilpoke:
Duh...you are missing 2 heatshield screws remember? That may be it....
You can get them here.
lakedrunk said:I didn't loose the screws, they were just loose. but that was back when I had my "cheatin" style exhaust on, I've switched back to my samsons now and don't have to worry about them little screws![]()
