1 - 11 of 11 Posts
I have an '06 VRSCSEII. I have read about many differant tuners to be used with the CFR including CFR tuner. I spoke with HD and they sell the CFR and will install an ECM and download the map. I would like to know if i would be loosing some flexibility should I make any further alterations by going this route. Should I use the PCIII or what???
Someone please lend me thier wealth of knowledge.
That U in my mirror?
I understand that if you intend to do other mods you may want to consider the SERT. I have an '06 SE2, Topless, Rinehart 2-1 and bought the SERT so I could play with my own Maps. SROD (Stu) on this forum got me started with 3 maps and I went from there.
Good luck whichever way you go.
I am running the CFR with a PCIII on My D .I had it dyno tuned runs great and I love the thunder the CFR makes good luck and ride safe
VRF0RUMS ORIGINAL
I have no experience with anything other then a PC III usb. As for the CERT I don't think you can go wrong with that either. Both are powerful tools to use and both can mess up your Rod in a hurry if you do not know what your doing with them. Either way go with a good known map to get it running and then get a custom tune by a trusted shop knowledgeable with either ECM controller you chose! Good luck you'll love the CFR! I know I love mine!
Will Work For Mod $$
And Ear Plugs.............:)
Dilligaf
I wouldn't let them do the flash, I would either use the CFR tuner,Gils box, PC3 or SERT.Unless you plan on doing engine mods later on you can't go wrong with a PCIII.
Cfr/ecm
Thanks you all for your input. It looks like the consensus is the PCIII is the ECM to have.
WHATEVER
The PC3 is not an ECM, it is a piggy back to the delphi ECM. Both the SERT and the PC3 are great tools. There a great MAPS posted for both applications as well.
I FINALLY GOT BOOST!
I had the PCIII and switched to a SERT. The SERT is very easy to use and doesn't leave anything on the bike (the PCIII stays on). You will love the CFR!!!
Dallas, TX
After listening to several folks piss and moan about issues they had with the CFR fueler and the PCIII, I went with the SERT and have not regretted the decision.
1 - 11 of 11 Posts
