On my 06 with mids, I was able to get a 17mm deep socket on the rear brake light switch with slim extensions for a 1/4” drive wrench that extend just short of the radiator and was able to torque it. I went in with the 17mm 5/8” socket with 1/4 to 5/8 adapter and one extension between the frame and the area just rearward of the switch, then moved the socket forward with a finger and screwdriver and slipped it onto the switch. I then went from the front by the radiator with another 1/4” extension. Then I put the wrench on. Larger width extensions don’t fit there.
I don’t see why removing the exhaust is necessary if you cover the frame from brake fluid. Is there any compelling reason why the manual says to remove the exhaust? Maybe this method could be of some help to someone doing this job.
