Justin Reyes
how do the stock exhaust mufflers come off?
i removed the two nuts that mount the passenger pegs and the single nuts towards the rear muffler and i loosened the clamp that goes around the muffler and exhaust pipe. what do i do next? i don't wanna ruin the stock mufflers.
Nuori mies nimetön
Now just wiggle it off, it can be tight. Mine was.
I see dead people
It helps to loosen the heat shield right beside the muffler inlet just to give you a little more "wiggle and pull" room. It will come off. I just did mine a couple days ago.
Sharks-Parts
make sure the muffler clamp is VERY loose... you can spray some penetrating lube between the muffler and the aux. volume and then use the wiggle - wiggle - wiggle method....
