i'm not sure if you were asking about my bar end mirrors or not, but i'll give my input.
i really like them, you can actually see what is behind you! i found them on ebay, but they were advertised for use on 7/8 bars. so i had to buy an adapter kit so i could use them on the 1" bars on the vrod. they were really easy to install, the hardest part was cutting a hole in the end of the aftermarket grip, that was gonna be big enough for the mirror to slide in. and it took some time filing down the inside of the throttle grip so it didn't stick at all. if you're interested in the mirrors more, i can look back through my records and get you the sellers name for both items. and like i said it was like a total of 20 or 30 bucks for everything.
one thing i had to get used to was that the objects behind you seem farther than they really are. and i know all motorcycle mirrors are like this, but these seem like things seem even farther than they did on the stockers. but seeing something is alot better than seeing nothing. IMHO
hope this helps
