Lip Smack'n Good
I am about to remove the swing arm and the manual states to shim up the motor so it doesn't fall after removal of the bolt.
How do you shim the motor up? It look's like there is a support plate that maybe can hold a wooden shim. Is this what it is talking about.
Do I even have to shim up the motor?
2005 VRSCA
Chrome is king!!!
2005 VRSCA
If you have the bike on a lift like the Craftsman jack it's not necessary since the lift will prevent the motor from dropping. At least I did it that way without any trouble.
'04 1300
I had mine on the lift, then stuck the swingarm bolt back in for added security after I pulled the swingarm.
Another Ski season
put the swing arm bolt back in, i tried to move mine a little on the jack after it was all apart and it shifted:banghead: If it does a large drift punch or an old wooden pool que will line things back up.
Pineland Underground
:them: ...done it twice now and no problems either time. So long as it's on a lift like this one mentioned above you have nothing to worry about.
Uh oh, I better check it out. I've been moving mine all around with the bolt removed.
