Rear tire sizes
956 Views 4 Replies 4 Participants Last post by  mikeinatlanta
Does anyone knows what size of tire u can put on the original swing (180)?
I have an 03 with a 180 tire, researched it as well as I can and 3/5 answers say a 200 will fit but just be super close. The other 2/5 say they had to grind a few threads off some bolts that point in from the saddlebags (if you have them) and maybe fender. I need tires this year and will be getting a 200 for the rear not worried. Fits the stock rim without hurtin the profile from the pictures I saw and what the people said.
The 200 rear tire will fit for 100% sure!
But some ppl says that u can put a 240 tire if u switch the belt and stuff..
200 will fit with minor mod in the inner fender area. or try this for 240
http://www.1130cc.com/forums/showpost.php?p=3895905&postcount=261
What is the intent of the tire? If for looks then the only issue is clearances. I don't think you will be able to go much bigger than 200 without getting into mods.
If performance then the 180 is faster and will handle better.
