Registered USDA
Just had my narrowed rear pulley powder coated. The back flange is now loose & the powdercoater said that it is common with pulleys when baked at 400deg +. I'm not comfortable leaving this flange loose & was thinking of using JB Weld. Has this happened to anyone & what did you do?
Don't use JB weld on this, is it possible to stake the ring without hurting the finish in an area that would be visible?
# 12/50 Ignite LE
JB weld! :spank: My chrome reactor sprocket has small button head screws holding the inner ring onto the pulley, I would check to see if that could be an option.
Registered USDA
What do you mean by "staking"?
Carefully beat the snot out of it, where the two surfaces join, as to create a friction fit. FWIW, Buell pulleys have no flange on one side. By the same token, I have seen crankcases repaired with JB Weld. What held it together before the 400 degrees? Probably an adhesive of some sort. The trick with the small screws would work, but make sure it balances. V/R Joe
Registered USDA
I'm going to run a light bead of clear silicone & see what happens.
To stake it you lay it on some thing that will protect the face and you take a center punch and you go around on the pulley itself and center punch about every inch or so just inside the ring on the pulley. It will swell the metal and make it push the area against the ring. It is called staking the metal.
Registered USDA
I'm going to try that method. You had me Googling staking and I found some stuff put mostky relating to plastics. Thanks for the lesson!
