1 - 1 of 1 Posts
Riding the Rev
Does anyone know if the piston size on the clutch master cylinder is the same as that on the front brake master cylinder? I am thinking of running a brake line to the rear bypassing the clutch. (Have other ideas for the clutch so will not need the clutch lever). However if the piston size is too large I won't be able to pull it.
Also are the caliper piston surface areas the same on the front and the back?
Thanks
1 - 1 of 1 Posts
