Will the rear fender off an '09 fit on an '06? And what would be a good price on a pretty rough used one, $30, $40, $50.....
I don't think so, 2 different frames. The 06 is a narrow frame, 07 and up has a wide frame.
At the top where the fender fits it is not wider. It will fit, even the bolt holes line up, you may need to do some minor fettling. I have a muscle rear end on my 03, almost fitted straight on.
My 06 nightrod had a 07-11 rear fender on it when I bought it. like they said above frame is a bit narrower and a factory seat was also widened to look right. I can say it will bolt on but you do need to modify the mounting holes.
