1 - 1 of 1 Posts
After reading the NRS on fire thread
http://www.1130cc.com/forums/showthread.php?t=142055
about leaking / burning rear brake light switches I decided to check mine even though the R uses a different part number.
My brake light switch was broken.
It was slightly wet inside the rubber boot. I don't know if this is a slight leak or lube sprayed in the connector.
I'm not a rear brake only person, but this is a safety item that should be "bullet proof". I don't know where the MoCo is sourcing the switches from, but clearly quality wasn't a high priority.
Please check your rear brakes and brake light operation.
1 - 1 of 1 Posts
