1 - 9 of 9 Posts
Movin' on....
:thumb: I think they would look hot!!!
Brake rotor will cover the spikes in the middle. I know they have matching rotors. But its still not the look you will have with out. Little trick I learned after looking at 100s of wheels . Put your thumb over the center and you will get a better ideal what its going to look like on your bike .
INFANTRYMAN
Most rims are a waist if your going to use the stock brake rotors, as it will cover most of it like said above.
I photoshoped a number of rims on to a DX to see how they would look, and came to the same issue.
So I researched the 360 brakes, and would allow the rims to be seen. If your going to drop the coin, I would suggest getting the 360 brakes, way more coin but pointless if you spend 3K plus and not be able to see the damn things.
360 brakes:
http://www.360brake.com/index.htm
Chad
really like the rim, maybe on my Nighttrain but for my DX....not so much.
MODOHOLIC ANONYMOUS
suicide out the front brake.. i am considering this even though i have matching rotors
The 360 brake systems installation guide states "360 Brakes can only be used on a wide glide style fork set"... I would have to assume that our v-rod does not fall into this category...
It appears they have a variety of fitments available. they even have a picture of a jap sportbike with two brake installed between upside down forks. Renegade is on the list of manufacturers the 360 Brake will fit so if you have an extra 2 grand i think you should give them a call. I would bet they could make it work.
In the Shark Tank!!!
I think V-Shop installed a set of 360 brakes on a V-Rod recently.. PM him.
1 - 9 of 9 Posts
