1 - 20 of 31 Posts
Wretched Excess.....
We have a perfect opportunity here to capture the results of different pipe combos, power adders and displacement increases will all the bikes being tested on the same day. What makes it great is that the runs were on the same dyno with the same atmospheric conditions. Please post the year of your bike, displacement, performance modifications, rear tire size and your resulting horsepower.
Please do not add comments to this thread, only your results. This will make a good reference for all those considering changing their stock pipes as well as those that want a different set of aftermarket pipes.
I'll start it off.
2003
1130cc
Trask Turbo - 8lbs Boost
200mm Metzeler
146.57 HP
____
Almost the same setup as you two but I hit at an even 140 hp...
I'll throw all the blame on the 240 Dunlop, had it been a Metz I would've given you guys a run for your money :rofl:
Still too slow
2002 'A' model
1130cc
200mm metzler
Supertrapp 2 into 1
Dobeck TFI
105.17
1130cc.comaholic
2002 A
1130cc
180 metz
$10.01 chopped (inner & outer baffles taken out) stockers off ebay :D
PCIII w/custom map from this wonderful forum!
108.55
Frank
'06 'R
Buell rear wheel with 210 x 17 Metzler with 40 PSI
1373 motor (with Destroyer heads and cams), eletcric water pump, extended oil pan, 6 nozzle injectors, 58MM TB....
V&H Indy pipe with baffle and packing in place.
Running rough tune with U4.2 race gas.
156.06hp (and still not peaked when it hit the 10,200 rev limit)
1130cc.com PITFA
Showroom stock 07 DX
1130cc
100.33 hp
103-104 db
Living Free...
2006
VRSCA
CFR Exhaust and SERT
Topless (ahem...the bike:spank: )
240 Rear Tire
118.9 Db
and 102 Hp
Thread Killer
2006 VRSCR 1130cc
Rinehart 2-1
SERT
K&N Topless
108.88 hp and climbing
120.1 db
Stock 180 tires
Bored
start time 31:30-32:17
115.9db
103.6 hp
1130
topless with SE filter
v-mod stockers wrapped
PCIII with homemade map.
hoping to see some 2-2 results here...seems that all the 2-1 and vmods are all close to eachother in HP....somewhere around 103 -108ish....
are the 2-2 alot lower?...keep em coming..this is awesome for us guys looking into which exhaust to buy....wish we had a thunderheader there that day...
dan
Bored
hafnutz67 has RH 2-2 @ 95hp. 120db
thanks for that info v-rod255.....so I guess that is real proof that the 2-2 will be less HP on same dyno same day....2-1 does make more power....It seems most the 2-1 are real close....cant wait to see the THundehdr 2-1 on this same dyno,as i really like that sound the best.
awesome!
"A" is the only way
('05 stock replacement motor)
210 buell rear
destroyer pipe
58 tb (due to 02 wire harness being different from 05 so had to use my 02 tb)
topless
108.68
Billy
Actually it was only 93.6 :spank:
It was blowing a good amount of black smoke as well. Looks like it's time for a retune..........or maybe a new pipe...........or turbo...............hmmm
1 - 20 of 31 Posts
