Can someone send me a picture of just the radiator fan & give me the diameter ? I'd like to see if I can talk Flex A Lite into making one of tier new Flex Wave fans for the VROD. You can pm me Thanks
Here's a Spal pdf document that Danno posted back in 2005. It shows a drawing of the radiator fan used for the VRSC.Can someone send me a picture of just the radiator fan & give me the diameter ? I'd like to see if I can talk Flex A Lite into making one of tier new Flex Wave fans for the VROD. You can pm me Thanks
What's the intent by doing this?Steve, big thanks. I'll see if I can get some traction with them to produce these. For late model we'd need two blade units in "pull" correct ? I'm hoping the blades can be swapped without replacing the motors & housings.
Did some research and it is interesting. I'd sooner see increased rad area to have the fans come on less but since we are stuck with minimal rad area and the need for fans, having them run for shorter periods due to increased efficiency is a good trade off. I did check and amp draw remains about the same, so that's good.Per the Flex A Lite press release, the design of the fan blades moves something in the range of 15-25% more airflow at the same rpm. Here is one release; https://www.dragzine.com/news/new-p...roduces-revolutionary-flex-wave-electric-fan/
