Hi i have a 2005 v rod and the radiator drain plug has snapped off in the radiator, i need to tap out the remaining plastic, do you know what thread the fitting is in the radiator. Cheers colin
Drill and easy out it out. OEM is the best option for replacing the plug. I've never actually gauged the thread but have reduced the plastic plug thread DIA to remove most of the friction as well as a light dab of grease on the threads. I've had it out a couple of times since, no issues. The plastic plug thread reduction was done by chucking the plug and a small tool to cut the thread a hair deeper and sandpaper on the OD after. Slow and easy trial fits along the way. This plug does not need interference fit because the o ring locks it in place when snug. Snug is the key word here.Hi i have a 2005 v rod and the radiator drain plug has snapped off in the radiator, i need to tap out the remaining plastic, do you know what thread the fitting is in the radiator. Cheers colin
Does the new plug have an Oring seal at the head and where did you get it?Thanks, got the remaining piece out, the thread is 1/2" - 20 UNF , i will put an aftermarket plug in, dont like the OEM one.
Yes but the bastards want 29 bucks to ship it to Canada. They can keep it. To me this part is only worth $5 bucks and there has to be one that's a direct fit with oring. I'll keep an eye out for one to add to my aftermarket parts list.Ron
Can`t confirm the thread size but:
https://www.ebay.com/itm/11-2092-11...e=STRK:MEBIDX:IT&_trksid=p2055119.m1438.l2649
