Hi Ron thanks for part number but i was thinking if there are alternatives/ Recommendations that differ from the Harley std?
Most likely the rad itself is the key component in attachment. Even up to the first part of 2013 they had the same rad part number which is 26722-04. The R has this same number for rad. They changed the rads in 2014 and up models but cover is the same as is the 4 mounting points, so from 04-05 ish to 2017 covers should fit, at least the rad itself. Beyond that, I can't say what fit issues you would have, if any. Hopefully some of the R owners will chime in with more details like any interference areas or if any trimming is needed.
