Quick throttle?
14K views 64 replies 13 participants last post by  bogie
#1 ·
Searching around for a 1/4 turn throttle and I only see 1 mention of G2ergo.com. Anybody have experience with this brand or any others? Throttle rotation is way too long. Thanks.
#8 ·
I,am running the G2ergo.com 1/4 turn on my DX. Install was straight forward but did have to remove the throttle lock. You can use standard grips.
Sent from Motorcycle.com Free App
#14 ·
I am using Kuryakyn Premium ISO Grips over the 1/4 Throttle kit, ho problems at all, I really was always concerned about using the screw / throttle lock as a cruise control so I had no issues in removing it when I installed the 1/4 turn throttle kit. it may be possible to keep it but to me it looked like it would not back off enough because of the quick ramp on the 1/4 turn throttle so I just pulled it out. I iso grips have a throttle boss that can be installed or removed so I just use that for long trips.
#18 ·
you dont have to twist as much the throttle when riding, they usually
come with different gears, 1/2 turn. 1/4 turn. and normal.
i personally get along great with this mod.
less stress on my wrist.
#25 ·
Interesting......annoys the crap out of me when i have to turn the throttle so far over.........I was reading somewhere that the F had "throttle by wire" or something like that.......but the dont.....i wonder if they did could you play around with the range more ???
#31 ·
Got the grips on. Wasn't as fast as 15 min. as others have stated, for me anyways. Avon grips were delivered as promised in about 3 days. The cam was significantly more aggressive in appearance than stock. Once mounted it is less of a rotation. Unfortunately I did not get a picture to compare before I put on. Sorry got in a rush. So far happy with the product and will be able to ride tomorrow. It will be a balmy 47 degrees and sunny.
#33 ·
top service from Avon, new grips built with G2 1/4 turn throttle are on the way :)
will post some pics up when I get them fitted, Im really looking forward to reducing the throttle travel
Avon have a nice range of grips, and are revising their website to offer the G2 Ergo 1/4 turn option publicly as they have had a few orders recently ......
