1 - 10 of 10 Posts
boo
Will 08 DX tins fit on an 07 DX?
Will 07 tins fit on an 08? ie, can i directly swap them?
if you know, how about the 07 vs 09, 10, 11 tins - same question.
thanks
Back in Black
If i remember right in 07 id the year they started switching. Some were steel some not. The pin is in a little different spot. I think with a little work they will fit. Just not a easy perfect fit. If they are both aluminum they should fit no problem.
brett
im not tottally sure but i would say they would fit cos some 07s have steel and some dont ,i thought wide frames were all the same it was the pre 07 tht required some jiggling to get them to fit ,,but again i may be wrong
yes, they are direct swappable. The only thing I'm not positive about is if they changed the front fender mount on the '08 and newer.
nope-I just put an 03 front fender mount on my 09 - fits perfect. The pins on the airbox are a couple of mm off, but the rubber gives enough so they work. short answer - yes, they fit.
1 - 10 of 10 Posts
